No brake lights or driver side door power
Old Feb 20, 2011 | 09:36 PM
phxmarc's Avatar
Default No brake lights or driver side door power
The brake lights and the driver side door power, plus overhead display stopped working on my 2002 monte carlo. Checked my fuses they seem fine.
Old Feb 20, 2011 | 09:42 PM
monte07's Avatar
it sounds like a power issue i would use a test light and a volt meeter. to see if there is a break some where befor the fuses i would start at the fuses and work back from there. i have done this befor on my silverado and the van i use to drive it ended up being a couple of power wires leading to the fuse box. also i would go and follow all the wires leading from the fuse box back far as possible to tell if any thing got fraid
gtpshawty
Sep 13, 2013 03:29 AM
Joe Bloggs
Nov 26, 2009 12:20 PM
jimbo7
Jun 25, 2009 09:23 PM
jogasz28
Feb 14, 2007 05:42 AM
