6th Gen ('00-'05): No accelerating when pressing gas while turning left
Had Cv joint axle replaced recently and upon replacing the passenger side.I've noticed that when turning left and giving my car gas all it does is rev up.It doesn't actually accelerate until I straighten out the wheel.That's after the passenger side cv joint axle was replaced. Does this mean the installation didn't seat properly or ??? It only does this when making left turns.
If you think it's the axle, I'd crank it hard and then reach in there to grab the axle and see if its loose on the transmission side.
I will say I've never seen that before though. Theres like 2 inches of spline engagement so it would have to pull out almost to the point of falling out of the transmission to do that (and then absolutely cook the diff with that huge speed delta).
Have you checked the fluid? I wonder if its uncovering the pickup on turns one way only due to low fluid.
If I recall, the N-Body and W-Body shafts are different diameters. Hopefully this issue does not follow (hopefully it gets corrected).
7th Gen ('06-'07): Vibration while accelerating?
TomF106SS
Feb 26, 2015 04:46 PM
indawuz
Mar 18, 2010 08:49 PM
