New thermostat - not much heat - temp gauge low
Old Jan 14, 2009 | 11:39 PM
mtc7's Avatar
Default New thermostat - not much heat - temp gauge low
1999 Monte Carlo Z34, 3800 engine. After the car is warmed up, the temperature gauge only reads in the 120-130 degrees max. I have replaced the thermostat 2 times. The car only blows slightly warm air after the car has been running for quite some time. Any help?
Old Jan 14, 2009 | 11:43 PM
Cowboy6622's Avatar
Default RE: New thermostat - not much heat - temp gauge low
I know sometimes you have to run hte car a couple times to get the thermostat to finally "break in" and run right... it may seem like a stupid questions but do you have enough water in it?
Old Jan 15, 2009 | 12:21 AM
mtc7's Avatar
Yes, I checked tonight. The coolant levels are good.
Old Feb 24, 2009 | 10:05 AM
ghess's Avatar
Check and see if the thermo you bought is a different temp too.....I used to buy ones that opened at a lower temp for motors I built.....
Old Feb 25, 2009 | 11:04 PM
mtc7's Avatar
The thermostat is 195 degree AC Delco factory replacement
Old Feb 26, 2009 | 12:02 AM
kweef's Avatar
i dont remember if u can do this on the monte but i know u can on some fords...did u put it in upside down lol
Old Mar 15, 2009 | 08:49 PM
skiinc's Avatar
Default Engine not coming up to temp.
I have the same issue with my 2003 Monte SS with the 3.8. I replaced the themostat with the proper temp. it is in correctly and the fluid is up to the proper level. Mine will only run at about 165-170. Usually a stuck themostat is the issue but not this time. Any other ideas to try???
Old Mar 16, 2009 | 05:40 AM
shotglass's Avatar
There are several things that could cause low operating temperatures. The first is the ambient temperature. Extremely cold weather (below about 20 degrees) will cause your engine to run cold. Too high of an antifreeze concentration will also cause this.
iMSeRiOuS
Jul 31, 2017 07:40 PM
mercury2
Mar 14, 2015 02:03 PM
04IntimidatorSS
Aug 4, 2012 10:14 AM
Scooby doo
Mar 23, 2010 09:56 PM
01whitess
Dec 20, 2005 03:29 PM
