6th Gen ('00-'05): Need to replace heater pipe, fuel pipes won't budge
Old Oct 6, 2019 | 01:24 PM
Laurel Clayton Costello's Avatar
Default Need to replace heater pipe, fuel pipes won't budge
I can't figure out how to get the two fuel pipe things out to get to heater pipe. What needs to be removed?
Old Oct 6, 2019 | 06:09 PM
Jeffs02rwdSS's Avatar
It appears you have bolts out , take a pry bar or screwdriver and give it a little help . It's held in by 6 o rings , 1 on each injector. Will also need to remove fuel lines. And use a little lube when you install it will help . Good luck
Old Oct 7, 2019 | 05:40 PM
Default Good one!
It totally just pried out, sorry to sound like a dummy, but I was stuck! Thank you!!
bw95monte
Jun 4, 2018 06:23 PM
Sinystyr
Apr 18, 2018 02:20 AM
2003 SS
Sep 24, 2017 08:38 AM
armando b
Feb 16, 2015 01:55 PM
codell17
Jan 28, 2012 02:45 PM
