Need info to add foglights to my 01 Monte Carlo LS
Old Feb 16, 2009 | 09:00 PM
kdawv's Avatar
Default Need info to add foglights to my 01 Monte Carlo LS
I want to add foglights to my car. I was looking at the size of the opening and was wondering if the Monte CarloSS lights and the lights from a 1997 thru 2004 Malibu are the same size or the same lights? If they are, does anyone know if the mounting bracket on the Malibu lights will work on a Monte Carlo? Does anyone have a pic of a Monte Carlo SS foglight with the mounting bracket to compare them?Any info is appreciated. thanks Keith
Old Feb 16, 2009 | 09:29 PM
nemesis's Avatar
2009 Monte Of The Year
Default RE: Need info to add foglights to my 01 Monte Carlo LS
97-03 malibu and the brackets are totally different
Old Mar 5, 2009 | 02:04 AM
robh68chevy's Avatar
Hey keith,
i actually added fog lights to my monte and hid a switch in the center concil. i have an 01 LS that did not come factory with fogs. what i actually did was measure the holes and buy aftermarker(huge price difference) for like 15 bucks from good ol wally world. the light is about 1/4 smaller then the hole for the factory fogs, so i centered them in the holes. if you have looked behind your bumper cover you have noticed that it is just a huge open space. that is why factory fogs would be nice because they would bolt right on. anyway i made custom brackets out of aluminum and bolted them to the metal bumper behind the bumper cover. they look good to me i dont have any pics with them on yet but i will get some. i also put yellow bulbs in. they contrast my hid's greatly.
well aftermarket is just an option. it takes a bit more work. let us know what you end up doing and post pics!
Old Mar 11, 2009 | 09:33 AM
jeff2425's Avatar
if you go gm you might need $300.00.or get lucky and find a pair in a junkyard. like robh68 I added some small oval shaped fogs that actually look and work pretty good. where you at in ohio robh68
File Type: jpg
File Type: jpg
Old Mar 11, 2009 | 12:18 PM
kweef's Avatar
rickcomatic has added fogs to his monte as well. he may be able to shed some more light
davidk67
May 10, 2012 09:21 AM
pizzarrhea
Mar 23, 2011 10:58 AM
Autobahndodge
Oct 16, 2009 10:36 AM
ludamike81
May 6, 2009 11:16 PM
06BlackSS
Oct 23, 2006 10:09 AM
