5th Gen ('95-'99): Need help with overheating
Old Mar 17, 2021 | 06:20 PM
Repent's Avatar
Default Need help with overheating
I had to replace the transmission in my 1999 monte carlo 3.1, I replaced it and drove it for a while with no issues and now I have an overheating problem. I replaced the thermostat and waterpump flushed the coolant and replaced it, the heater core isnt clogged nor is the radiator, theres no coolant in my oil nor oil in my coolant. The catalytic converter isnt plugged and the air intake works fine. I want to say that its a problem with the head gasket sucking in air because the coolant is either boiling or its bubbling and its the only thing I can think of that could be causing my issues. Any ideas? Edit: took off the whole topside down to the head gasket and found coolant in there so lets hope theres not a bigger problem than just this gasket 😅
Old Mar 18, 2021 | 08:17 AM
Are the Fans working properly? maybe they got unplugged or a relay is out on them.
Old Mar 18, 2021 | 04:13 PM
Repent's Avatar
Yes the fans work properly
Old Mar 19, 2021 | 05:46 PM
Question
then you got a head gasket that is bad!!! I just replace them on my suv 3400 at $1800.00 they also re-plained the heads as well. I had them put in new plug's while it was easy to do.
Old Mar 19, 2021 | 07:25 PM
Repent's Avatar
Default I had the same idea lol
LawsBlueMonte
Mar 25, 2019 09:57 PM
DougJK
Sep 27, 2018 07:30 AM
apguy
24
Feb 19, 2012 08:18 PM
anthony_8606
Feb 1, 2012 08:10 AM
yzfman98
Oct 25, 2010 02:46 AM
