1998 Overheating Problem
Old Oct 22, 2010 | 05:39 PM
yzfman98's Avatar
Angry 1998 Overheating Problem
My 1998 Monte Carlo is overheating. I have replaced the water pump, thermostat, & relays. I have also bled the system of air. It keeps overheating and stays hot and I get no heat at all. I have trouble shot everything according to the book and am not sure what to do next. My low coolant light keeps coming on also but the coolant is not low.
Old Oct 22, 2010 | 08:33 PM
labnjab's Avatar
I would suspect a head gasket. Are you loosing any coolant? Does the exhaust smell like burning coolant (kind of a sweet smell)?
Old Oct 22, 2010 | 08:52 PM
mrl390's Avatar
Did you check the thermostat before you put it in? I have gotten brand new thermos that were bad. I would also try and bleed the system of air again. Sometimes you can get a bubble trapped and its real hard to work out.
Old Oct 23, 2010 | 09:30 PM
Squeegee's Avatar
check all the gaskets, when i had a coolant leak it took 5 months to have it figured out. after i replaced the waterpump, thermostat, and heater hosees (which where actually leaking), i took it apart and did the l.i.m's, and it still had the same issue. turns out it was the timing chain cover gasket.
Old Oct 23, 2010 | 10:01 PM
nitehawkjcb's Avatar
Check your heater core
Old Oct 25, 2010 | 02:46 AM
If it's a 3.4 I'd check the lower intake manifold gasket. They are known to fail due to a poor design.
Bessy
Oct 17, 2013 02:22 PM
Mechanically Declined
Jan 19, 2013 01:38 AM
simdog765
Nov 28, 2011 10:38 PM
misio66661
Jul 8, 2009 05:45 PM
redneckmc
Oct 1, 2004 09:39 AM
