Need help, intermittent dash lights not all working, and only rear running lights
Occasionally my dash cluster " lights and gauges" don't all operate when I start the car and only the running lights front and back of vehicle would work with the switch on in the auto light position but would turn on if manually switched on, but lately my rear brake and running lights won't work at all including rear blinkers and hazard don't turn on at all period, but the running lights in the rear will still switch on manually just not the rear hazards blinkers or brakes, I've already checked all my fuses and bulbs and the multi switch is brand new I need any advise from anyone at this point currently walking to work as a mechanic is a bit embarrassing..
