7th Gen ('06-'07): Need Help - I'm Clueless
Old Aug 8, 2025 | 05:25 AM
MikeMcD1973's Avatar
Default Need Help - I'm Clueless
2007 5.3 SS and I have an issue that is kind of hard to explain, but here it goes. The issue is while I'm driving the car is running smoothly and then it all the sudden will bog down and if you give it a little gas it will smooth out but goes back to bogging down. If I am coming to a stop and it's having the issue, I have to put it in neutral or it would probably shut off.
If anyone can point me in the right direction or have any ideas of what it could be I would greatly appreciate it.
Old Aug 8, 2025 | 12:34 PM
Id start with testing the o2 sensor and all the sensors under the engine. Is its switching from 4cyl/8cyl while you have the problem?
Old Aug 8, 2025 | 02:02 PM
No not changing from 8cyl, I do have a P0327, knock sensor low voltage and I have changed both the sensor and harness in Bank 1.
Old Aug 12, 2025 | 02:17 AM
Old Sep 1, 2025 | 04:57 AM
No not switching from 4cyl to 8cyl
Drew Watson
Jun 21, 2023 12:38 PM
hunterlee
Oct 11, 2022 10:22 PM
Catevari
Sep 18, 2015 01:53 PM
S.O.G.
Sep 5, 2015 12:08 AM
tylerh0717
Jun 4, 2015 09:44 AM
