6th Gen ('00-'05): Need help finding where hose goes
Old Nov 26, 2024 | 02:52 PM
Hamdawg's Avatar
Default Need help finding where hose goes
Hey folks, need your help finding where this hose goes on my 3400 sfi throttle body.. it deteriorated and I have no idea.. any help would be greatly appreciated..
Driver side
Driver side
Old Nov 26, 2024 | 08:50 PM
Smile
Well I went to Google and did a search and found some pictures for you. This might help some!?
its a Vacuum line of some sort.
Old Nov 27, 2024 | 03:43 AM
I have a diagram in my pictures I think, Ill look real quick.
EDIT: Yea here it is. Originally MINE was capped off and unused so I put a vacuum gauge there.
If you are positive you had a vac line there, I think it should go to the MAP.
Mine was an '02 btw.
Wow that was a while ago... Sorry, just typing out loud.
Old Nov 28, 2024 | 08:26 PM
Hamdawg's Avatar
I appreciate it. Yeah there was a price deteriorated rubber hose and I’ve looked all over trying to find the other end with no luck. While car is running it the rpm’s fluctuate at idle and if I put my finger over hole it kills the vehicle.. I’ve been running it like it is but now the car is throwing po171 & po507 codes.. but anyway much appreciated
Old Nov 30, 2024 | 03:37 PM
I know on the 3400 Grand Ams, there is a vac line there (I believe it feeds the HVAC controls). I know in a 2005 Impala (which is like a Monte), that I used to work on, it was just capped off. But, somewhere from 2000-2004 GM changed the HVAC controls from vacuum controlled to all electronic controlled.
What year is your Monte as that may have bearing here. And if there was a vac line connected to it, is part of that old line still lingering around the engine?
Old Dec 1, 2024 | 06:35 AM
Is there another nipple on the backside of the manifold? On my 02, the rear nipple was used and the front (where I have the hose connected) was capped off from the factory. I believe the rear went to the MAP.
Justchambers88
Feb 4, 2022 05:23 PM
Bryan Aytes
Apr 29, 2021 03:07 PM
Abonillas
Feb 1, 2021 08:33 PM
zachary
Apr 17, 2011 05:44 PM
