Multi-function switch
Old Apr 14, 2010 | 11:54 AM
artlawton's Avatar
Default Multi-function switch
Hello. (hope I'm doing this right). I have a 2000 Monte Carlo SS. I'm told I need a new multi-function switch. I have not been able to find it on any of the online parts stores. I'm wondering if it was called something else in 2000? I see they are available for newer models.
Any help would be appreciated. Thank you!......scott
Old Apr 14, 2010 | 12:17 PM
saigashooter's Avatar
I think the part should be the same, the 6th generation Monte Carlo didn't change much during it's 5 year run.
That said, if you don't mind a used part, check out Morad they have a ton of parts for FWD GM cars, and are happy to answer any questions on parts they might have.
Old Apr 14, 2010 | 12:56 PM
monte07's Avatar
also genuingmparts.com will probably have it as well they will help you out as well
Old Apr 14, 2010 | 01:04 PM
JAFO's Avatar
Says 01+ ...is 00 different from 01+ ? At any rate you may want to give morad a call too.
http://cgi.ebay.com/ebaymotors/2001-...Q5fAccessories
Old Apr 15, 2010 | 08:23 AM
artlawton's Avatar
Default Multi Function Switch - thank you
Thank you very much for your responses regarding the multi function switch. I will check out these websites today. Really appreciate it.......scott
monteride
Sep 2, 2013 06:03 PM
Jomao_o
Nov 26, 2012 06:22 PM
muleys99
Jan 15, 2011 09:43 AM
98Z34
FWD Tech Guides '95-'07
Sep 27, 2010 10:27 AM
ohsuzanna
Aug 19, 2009 04:47 AM
