more than one issue
Old May 7, 2013 | 12:43 PM
mommyof3's Avatar
Unhappy more than one issue
i am an owner of a 2003 SS. My car seems to be having several issues in which i can't figure out. First sometimes the security light comes on and it won't crank. when it does crank the traction light and security light and the ABS light comes on. I have took it to my teck and he don't know how to fix it. SOMEONE PLEASE HELP!!
Old May 7, 2013 | 01:15 PM
03SSLE's Avatar
The problem when the security light illuminates is caused by the Passlock system. For some reason the ignition does not recognize the key, so the car will not turn over. Sometimes when it happens a security relearn process will fix it:
This takes approx. 35 minutes to complete:
Turn key to ON position and leave it there for 11 minutes.
Tuen key to OFF position and leave there for 10 seconds.
Repeat the above procedure 3 times, then start the car.
If the above doesn't resolve the problem then the Passlock system will need to be diagnosed, or some have elected to bypass the Passlock system. A search for Passlock Work Around will net lots of information on how it is done.
A common cause for the ABS and TRAC lights to come on simultaniously is a bad wheel bearing. The bearing and ABS sensor are both contained in the wheel hub. When the bearing wears it skews the ABS sensor signal and the computer thinks there is a prblem with the ABS system. It (the computer) sets the ABS light and disables traction control which sets that light. Replacement of the wheel hub usually resolves the problem. Physical inspection of both front and rear wheel hubs is required and/or the computer needs to be scanned to see which wheel triggered the code.
Edit: I forgot to mention cleaning the key (rubbing alcohol works) before doing the security relearn. If it's dirty that could be why it isn't recognized.
DAVESS2002
Aug 22, 2016 08:21 PM
HIxArsenaL
Jul 8, 2014 03:32 PM
Longislandmonte
Dec 6, 2013 03:25 PM
new2monte
Apr 1, 2007 11:24 PM
smolek37k
Nov 8, 2006 12:41 PM
