One fog light dimmer than other?
Old Dec 5, 2013 | 10:42 PM
Longislandmonte's Avatar
Question One fog light dimmer than other?
Hi guys, ive been having a few problems with my fog lights recently. It seems like sometimes one fog light is dimmer than the other one. I own a 2006 3.5L Monte Carlo LTZ. I don't know much about the fog lights, maybe a wiring problem? faulty bulb? Im not sure.. Im planning on putting blue bulbs in my fog lights either way but I have a need for everything on the car to be perfect before I move on to the next step; im sure you guys understand. Any help at all would be great! Thanks!
Old Dec 6, 2013 | 07:31 AM
It could be a faulty bulb issue or just a simple ground connection...
I would check and clean all the connections at the ground level. maybe something as simple as a wire brush and a little elbow grease?
Old Dec 6, 2013 | 07:37 AM
More than likely it's just a bulb going bad
Old Dec 6, 2013 | 01:01 PM
Alright thanks guys. Ill check it out as soon as it stops pouring outside
Old Dec 6, 2013 | 01:12 PM
Easy test, just swap the bulbs around and see if the dimming follows.
Old Dec 6, 2013 | 01:32 PM
Does anyone know how to actually get to the fog lights in the 06/07? There sure does seem like a lot to take off!
Old Dec 6, 2013 | 01:43 PM
I think the easiest method is removing the headlight housing and then reaching down.
The headlight housing is really easy to remove though, just one clip and 1 screw, then unplug and set aside.
Old Dec 6, 2013 | 01:52 PM
dbaldwin's Avatar
You can just get at the bulb from underneath. Thats how I did it.
Old Dec 6, 2013 | 03:25 PM
Okay ill try it out first thing when I get the chance, thanks guys!
ded548
May 6, 2020 09:47 PM
HIxArsenaL
Jul 8, 2014 03:32 PM
BeachBumMike
May 7, 2014 10:09 PM
Absolutpolack
Apr 26, 2010 02:43 PM
silent357
Jul 24, 2009 08:00 AM
