6th Gen ('00-'05): Monte wont startall th time
Old Sep 20, 2014 | 12:58 PM
little red ss's Avatar
Unhappy Monte wont startall th time
Hello all,
I have a 2001 monte ss and I m having issuses with it starting. You have to turn the key a dozon times or so befor it will even crank, then it will be fine for a few times then you let it sit over night it wont crank can any one help me?
Old Sep 20, 2014 | 01:07 PM
Hi Little Red Monte,
Sorry to read about your problem It's sounds like it could be (?) a Faulty Ignition ?Check the below & also check back to see what our other member's post to help you with your present problem > Good Luck <
Old Sep 20, 2014 | 02:42 PM
Most Models have had ignition switch issues....
Your may have been in the recall (I'm not sure)
But I'd be curious to know if...
You put it in Neutral... Will it or does it start properly then?
Doing so... will also eliminate the possibility of a faulty Neutral safety switch.. If it starts right up...
schoentges16
Feb 27, 2021 06:43 AM
BrandonStebing
Jul 25, 2014 11:03 AM
warriormagee
Jul 11, 2011 02:05 PM
BocaReject
Apr 13, 2011 07:36 PM
Dave McFly
May 11, 2008 08:28 AM
