monte runs rough at first start up
Old Mar 11, 2012 | 03:04 PM
blackbeauty89's Avatar
Default monte runs rough at first start up
i've noticed this has been getting more frequent the past few days, but at initial start up, my monte will run pretty rough. it'll chug and sputter and rpms will bounce up and down. but after a bit it'll run fine and not miss a beat.
no CEL comes on, and it runs fine other than that. i have noticed my gas mileage hasn't been too good either though.
Old Mar 11, 2012 | 06:44 PM
possible fuel pressure regulator? once and awhile i'll get a long crank time too. and i know those are a common issue.
Old Mar 11, 2012 | 09:18 PM
Rellsun's Avatar
Why not just rent a fuel pressure test from auto zone or advance. Should help narrow if down.
Old Mar 11, 2012 | 09:40 PM
MONTE2000SS's Avatar
im having same issue but its not alll the time if it dont get driven for two day or more seems to do it
Old Mar 12, 2012 | 08:16 AM
Pull the vacuum line from your FPR and smell it, if it smells like gas it is bad.
You could also just really need a good cleaning of the TB and sensors
Old Mar 12, 2012 | 08:28 AM
Default heres what i did with mine
mine did that for the longest time...witn no codes etc.....changed everything...still had the same problem......just out of curiosity.....i started cking everything i could.....til 1 day the MAF failed and it ran like crap...huffn spittn poppn etc.....changed it out (new) MAF...and problem solved....but i had 120,000 miles on mine.....when i started messn up...
Next time it does it...unplug the MAF and see if it smooths out...if it does...thats the problem....
Hope this helps
Old Mar 12, 2012 | 06:57 PM
Well I smell fuel lol
Old Mar 13, 2012 | 10:11 AM
Well there ya go
Old Mar 13, 2012 | 11:42 AM
Rellsun's Avatar
That's cool I never knew that. I love all the cool little tricks you learn here.
Old Mar 13, 2012 | 11:53 AM
If you pull the line and gas comes out... you have had a bad FPR for a pretty long time lol
HammerZR1
Sep 29, 2013 12:44 PM
95montecar
Jan 30, 2013 01:26 PM
silver86
Dec 25, 2011 11:59 AM
blondeguy64
Mar 10, 2010 07:44 PM
les1178
Nov 29, 2007 07:46 AM
