monte has a whistle
Old Jan 1, 2015 | 06:50 PM
gertis's Avatar
Default monte has a whistle
04 ls 3.4, did thermostat and then it wouldn't start, would immediately shut off. Unplugged MAFS and now the car stays running but whistles loudly and revs high. I'm lost. Any ideas
Old Jan 1, 2015 | 10:53 PM
nitehawkjcb's Avatar
Sounds like the MAF could be messed up. The whistling could be a vacuum leak.
Old Jan 7, 2015 | 10:33 AM
gertis's Avatar
Yeah it turned out to be a leak in a hose. Got that fixed and the thing still overheats and blows out nothing but cold air. Thinking heater core?
Old Jan 7, 2015 | 02:47 PM
Overheating could be from air in the coolant system, as could the heat issue. Try bleeding the coolant (of course adding antifreeze if need be), but it wouldn't surprise me if the heater core was failing - or even the water pump or an intake gasket leak.
Old Jan 7, 2015 | 04:58 PM
Has it been using/leaking antifreeze?
If so,
I'd have to agree.. could possibly be bad intake gaskets.. and with air in the system.. would be a good reason that you don't have any heat.
80sselky
May 17, 2011 04:13 AM
saigashooter
May 25, 2010 07:32 AM
Jordy
Dec 30, 2009 08:56 AM
88ss408
Dec 20, 2006 01:22 PM
malletboy
May 3, 2006 09:39 AM
