6th Gen ('00-'05): Monte Electrical / Ignition
In reading posts,, the problem we are having could be the dash mounted ignition switch, the patient is a 2000 Monte Carlo, 3.4L. What it does, Cam Sensor Error Code, keeps returning, have installed a new cam sensor, code still returns. Multiple miss-behaves along with cam error code, when wipers are turned on they work, but will be slow to turn off,, or may stop in mid stroke,, turn signals will quit working, then if ignition is turned off, then back on, they will work again, car will stall at stop light, today I noticed at idle,, then when revved up just a little, tach drops slower, and dash lights / mileage light dim for a split second,,,,,,,,, jeepers,,,, can the ignition switch make all that stuff happen ?
Sorry to read about your Monte Problems. Check back to see what our expert tech member post when they view your thread. Until then you may want to check out the below information. Good Luck
" target="_blank">
www.doityourself.com/stry/symptoms-of-a-bad-ignition-switch
If your vehicle is having trouble starting, it could be showing signs of a failing ignition switch. Some symptoms may be similar to other problems like starter motor ...
www.aa1car.com/library/ignition_switch.htm
The ignition switch is the master switch that provides power for the vehicle's electrical ... The cause may be a bad solenoid, an electrical fault between the ignition switchcircuit and the ... This is one of the most common symptoms of a worn ignition switch. .... Cadillac Deville, 2000-2005 ... Chevy Monte Carlo, 2006-2008.
" target="_blank">
▶ 1:50
https://www.youtube.com/watch?v=YWvVkJtkE2Q
Jan 23, 2015 - Uploaded by GMManiac
Ignition Switch Failure - Symptoms (TrailBlazer/Envoy) .... How To Replace Install Ignition Switch 2000-05 ...
" target="_blank">
▶ 10:37
https://www.youtube.com/watch?v=LSfqZJ3FQrA
Apr 24, 2014 - Uploaded by RatchetsAnd Wrenches
Here is how you can replace an ignition switch on a 2005 Chevy Monte Carlo. ... +batterista The switch ...
" target="_blank">
▶ 2:47
https://www.youtube.com/watch?v=fWYhYx8bMWg
Oct 5, 2014 - Uploaded by Thomas EXOVCDS
VW A3: Signs of a bad Ignition Switch ... Ignition Switchreplacement: ..... How To Replace Install Ignition ...
" target="_blank">
▶ 1:44
https://www.youtube.com/watch?v=DGaXLXuOxGg
Dec 31, 2014 - Uploaded by phigo4kins
2005 Chevy Impala BAD Starter Symptom [Infamous GM No Start No Crank Issue] ... This same problem ...
www.topix.com › Chevrolet
Apr 15, 2010 - I have a 2000 Chevy Monte Carlo (base model) and it randomly will not ... but I think it may be something behind the ignition switch going bad.
montecarloforum.com › ... › General Forums › Monte Carlo Repair Help
May 28, 2009 - 2001 Chevrolet Monte Carlo. Trader Rating
0) ... Do anyone know how to REPLACE a ignition switch solenoid? I am trying to cut cost and know how to repair my own problems. If anyone can .... Tags · 01, 02, 2000, carlo, change, cylinder, ignition, ingition, key, lock, monte, putting, stuck, switch, turn, wont ...
0) ... Do anyone know how to REPLACE a ignition switch solenoid? I am trying to cut cost and know how to repair my own problems. If anyone can .... Tags · 01, 02, 2000, carlo, change, cylinder, ignition, ingition, key, lock, monte, putting, stuck, switch, turn, wont ...www.gminsidenews.com/.../02-monte-carlo-intermittently-will-not-start-...
Feb 24, 2011 - I seem to have a crazy issue with my 2002 Monte Carlo SS. In October, she started up when I picked my kids up from school, went to gas station ...
www.gminsidenews.com/forums/.../2000-monte-carlo-wont-start-62381/
My son has a 2000 Monte Carlo SS with an ignition problem. What happens: Turningignition key to on, security light comes on momentarily( as has been.
