6th Gen ('00-'05): Monte Carlo sputtering question.
I have a 2005 Monte Carlo Tony Stewart Edition. It has a lot of miles, I just reached 202,000. The question I have is it sputters, or bogs down when I either go up a hill, or hit about 60 on the interstate. The check engine light also flashes for about 15-20 seconds. It only does it in those two instances. It drives fine any other time and the check engine light doesn't stay on. I have replaced the plugs, wires, coil packs, Catallyic Converter and air flow sensor within the past 8 months. It just started doing this within the past three. The only thing I can think of is a fuel injector maybe. Any suggestions on what could be causing it?
DJ_bosse is right, the flashing is normally a mis-fire. But the computer should still have a history of the code thrown (might take a better scan tool that can read that part of the computer). A mis-fire code can narrow you down to a specific cylinder or inform that it's a random mis-fire. Either way, it helps you pin point where to look for the cause of the problem.
