7th Gen ('06-'07): No Sound in Front Left Speaker
Old Oct 30, 2016 | 10:25 PM
BSHAW94's Avatar
Default No Sound in Front Left Speaker
No sound is coming out of the front left speaker except for very high frequencies and can barely be heard. On the RARE occasion it will come back to life, but will only last like 10 minutes.
All the other speakers are working, so I don't know if it is a wiring issue or a problem with the radio itself. Does anyone have a solution or has anyone experienced a similar issue?
On a side note, the door chimes and signal sound can't be heard either...
Cheers
Old Oct 31, 2016 | 07:30 AM
WBody's Avatar
I'd start with wiring then speaker, finally radio. Check the wire and swap a different speaker over. What year? Stock setup?
Old Nov 2, 2016 | 05:24 PM
BSHAW94's Avatar
Default Reply
I have a 2006 ltz, stock every thing, no amp with the speakers. Which wire would I be checking and where is it located?
Old Nov 2, 2016 | 09:01 PM
Barovelli's Avatar
Pull the door panel off, remove the speaker and hook up another speaker in its place. Even an old speaker and some zip cord twisted to the plug & terminals is good enough to test if the head unit is outputting.
http://www.barovelli.com/projects/ca...edoorpanel.htm
I'm stuck with a no sound from right front. It's not the speaker so I sometimes try to eliminate the radio or the stock amp. Mostly I push the fader to the back speakers and turn up to volume.
