Monte Carlo Problems/Answer's ?
Old Apr 27, 2008 | 08:46 AM
Default Monte Carlo Problems/Answer's ?
[align=center]Source[/align][align=center][/align][align=center]
Hear [/align][*][align=center]See [/align][*][align=center]Feel [/align][*][align=center]Smell [/align][*][align=center]Engine Related [/align][*][align=center]Breaking Related [/align][*][align=center]Tire Related [/align][*][align=center]Transmission Related [/align][*][align=center]Steering & Suspension Related [/align][align=center]Starting Related[/align][align=center]
[font=arial][size=-1]Clunking noise during braking [/align][ul][*]There are worn steering system components[*]The disc brake caliper is not mounted properly[*]Some of the brake hardware is damaged or missing [/ul]
The brakes squeal when they are applied
[ul][*]There is dirt on the brake rotors, drums, pads, and/or shoes[*]The brake pads and/or shoes are worn[*]The brake pads were overheated and are now glazed[*]The disc brake calipers were mounted incorrectly or have come loose[*]The wear indicator on the pads are contacting the rotor [/ul]
The transmission grinds while shifting gears
[ul][*]The clutch needs to be adjusted[*]The clutch is worn[*]There is internal damage to the transmission[*]The shift linkage needs to be adjusted [/ul]
Squealing from engine while accelerating
[ul][*]The drive belts are slipping[*]The drive pulleys for some engine accessories are misaligned[*]You have turned the steering wheel to the limits[*][URL=http://ca.autos.yahoo.com/maintain/
Old Apr 28, 2008 | 07:55 AM
Default RE: Monte Carlo Problems/Answer's ?
[align=center]Member's,[/align][align=center]Click on below link to read questions, and answers[/align][align=center]on the Chevrolet Monte Carlo[/align][align=center]Hope it helps someone [/align]
Chevy Monte Carlo Questions
[align=center]Total questions: 1165[/align][/align][/align][/align][align=center]Click below link[/align][align=center][:-][/align][align=center]http://wiki.answers.com/Q/FAQ/1047[/align]
Old Apr 28, 2008 | 11:54 AM
My Zone
Register with AutoZone.com
Take advantage of our services by registering with us. Registered users can checkout faster when they purchase parts online. Plus, you can receive special personalized information about your vehicle, including Technical Service Bulletin titles, recall notices, service reminders, your vehicle's service history and plenty of other stuff. You don't have to register online to buy parts.
If you're already a registered user, Login.
My Profile:
Your profile has all of the information you've shared with us. You can use the links to change your password, edit your profile or remove it. You can also view your order history and check the status of pending orders.
My Vehicles:
My E-mail:
When you register with us, you can receive special personalized information about your vehicle, including Technical Service Bulletins, recall notices, service reminders, your vehicle's service history and plenty of other stuff[/align][align=center]Click on below link to go to site[/align][align=center][:-][/align][align=center]http://www.z.net/[/align][align=center]MCF `Member's, `if you have any helpful repair/parts sites[/align][align=center]please post. Or sites like above that assist owner's[/align][align=center][/align][align=center]MCF = Member's helping ~> Members [/align][align=center]That's 4-Sure [8D][/align]
Montes4me
Aug 28, 2013 10:10 PM
rj
Jan 8, 2007 03:29 PM
79Monte
Jan 8, 2007 04:57 AM
04MonteLS
Jun 5, 2005 03:41 PM
