4th Gen ('81-'88): Monte Carlo 1985 won't start
Old May 30, 2019 | 10:10 AM
Question
Originally Posted by Patrick Sam
I noticed that little metal clip and what holds it down is broken would that make a difference?
If you are referring to the rod that you turn the screw at the top that hold the Dist. Cap down yes.
I am seeing a condenser that could be as old as I am in this photo. The rotor needs to make contact with the metal posts on the underside of the Dist. Cap. It can't do that the way it looks in the photo the metal clip on the rotor in the pic is not installed it will need to make contact with those posts.
If the Points in this thing are old they should be replaced as well. Then the Coil could be an issue as well.
Old May 30, 2019 | 11:07 AM
volkerc's Avatar
The rotor is trash. No wonder it doesn't run. It is missing the metal pieces to distribute spark to each cylinder. Question is, where did it go? Look if it's down in the distributor. Might also want to check the hei cap if the center coal piece s gone as well. Hei distributor should have no points to replace.
Old May 30, 2019 | 11:23 AM
volkerc's Avatar
pic of a new rotor, see what's missing...
Old Jun 1, 2019 | 02:52 PM
volkerc's Avatar
So, is it running again?
Deshun Deathbefore Dishonor
Feb 6, 2019 05:10 AM
Alex234
Aug 22, 2017 05:26 PM
MonteCarloss84
Oct 23, 2013 07:37 AM
sykesent
Apr 26, 2006 01:03 PM
FullGhettoMonte
Jan 2, 2006 01:36 AM
