4th Gen ('81-'88): I want my 81 monte carlo to start
Old Jun 20, 2017 | 05:56 PM
Alex234's Avatar
Default I want my 81 monte carlo to start
My dad bought a 81 Monte Carlo a long time ago, and it was almost empty, no interior but the dash and all but it won't start, the engine looks brand now, it cranks but it won't start, I was thinking it probably needed a new carburetor, but I'm not sure, need help!
Old Jun 20, 2017 | 09:51 PM
Smile
To big questions are
1. does it have spark? Take a plug out and have some one crank it, hold plug near the header/manifold and see if the spark is jumping to the metal.
2. is it getting fuel?
Old Jun 27, 2017 | 08:50 PM
Alex234's Avatar
Default Yes
its getting fuel and it sparks
Old Jun 28, 2017 | 07:03 AM
user 35764368's Avatar
if its sat for a long time...maybe the cylinders have lost compression.... try pulling the plugs and putting a small amount of engine oil in each plug hole to lube them up and that will restore compression.
Old Aug 22, 2017 | 05:26 PM
DAVESS2002's Avatar
Sounds like the timing might be off. Best way to check is to take out the #1 sparkplug and turn it over with a wrench on the crank bolt. Hold your finger over the spark plug hole and you can feel the compression stroke. Stop turning when the piston is at the top and your distributor should be lined up with the #1 terminal on the cap. I know when I changed the intake manifold on my ElCamino I had the distributor off a tooth and it would not start. Pull the dist. and make sure the rotor lines up with #1 terminal on the cap and it should start.
