Misfire? I can't tell....
Old May 3, 2014 | 08:59 PM
Hiroska's Avatar
Default Misfire? I can't tell....
Idlea good but at certain times during the rumble it'll rumble harder but then goes back
Old May 4, 2014 | 10:32 AM
JC Colon's Avatar
I couldn't hear anything more than your radio. What is it that you are seeing.
Old May 4, 2014 | 12:18 PM
Hiroska's Avatar
My Rpms slightly jump during an idle, it's hard to tell without staring at it hard. At the point where I say see, see it that. That's the point after I rev it, it slightly jumps.
Old May 5, 2014 | 08:20 AM
Could just be something simple like a dirty MAF. You'll know a misfire when it happens.
Old May 5, 2014 | 11:08 AM
JC Colon's Avatar
WHAT Mike Said is true, when my car had a missfire it lacked power and the engine would bog when I tried to accelerate.
Old May 5, 2014 | 11:56 AM
03SSLE's Avatar
I agree with the possibility of it being a dirty MAF, especially if you run an oiled air filter. It's very easy to over do it when it comes to oiling them. Clean this first. Other possibilities could be carbon build up on the seat of the IAC. I would also check for carbon/varnish build up around the throttle plate or shaft binding. In either case, a good cleaning should resolve the fluctuating idle if they are the cause. It's impossible to give an exact diagnosis online, but just listening to the video I'm thinking carbon build up of the IAC seat. The drop in idle then 'catching itself' to come back up to normal idle is what makes me suspect the carbon build up. It could also explain the momentary drops in rpm while idling. A piece of emery cloth dipped in fresh oil does a great job cleaning the IAC seat. You can also clean the end of the pintle the same way.
Theflash2515
Sep 15, 2010 07:29 PM
mattilus2121
Mar 16, 2009 09:03 PM
BeachBumMike
Dec 9, 2007 08:25 AM
trbochrg
Jul 10, 2007 08:20 PM
