MC Idles at 3000 rpm when I start the car
Old Mar 18, 2015 | 11:30 PM
bigmyyke's Avatar
Default MC Idles at 3000 rpm when I start the car
Hi, I have a 2003 Monte Carlo ss 3.8L I had just install all the solenoids in my transmission. The Tcc, both shifts solenoids and epc on the valve body. After reassembling the car, I started the car and my engine revved immediately to 3000 rpm and would stay idled at 3000 rpms until I shut the car off.
I disconnected the ground on battery and waited 30 minutes and tried it again. It revved up again but this time about 2000 rpm. While running still I pressed on the gas pedal and it felt like there were some tension. It would rev up higher and lower as I pressed and depressed the gas pedal but not getting any lower than 2000 rpms.
I turned the car off again and disconnected the battery for 15 minutes. When I stared the car again it immediately revved up to 3000 rpm. I shut the car off right away.
I am stuck at this point. I am not sure if I need a IAC or TPS sensor or both. The car ran fine before I changed out the solenoids in the transmission. Could I have did something wrong there?
Would it be the IAC? I've read that FI I disconnect the IAC and start the car it should rev high. Then If I re-connect the IAC and the engine still revs high than the IAC is bad. If the IAC is good it would idle correctly. any truth? Thank you all in advance.
Old Mar 20, 2015 | 11:33 AM
Slugger088's Avatar
Monte of the Month -- August 2013
I think it just may be the IAC like you say. I had a similar problem on my old car and that was the issue.
However, because it happened right after you had transmission work done, I am not 100% on it.
YelloJac
Oct 14, 2012 11:37 PM
monte carlo 3831
Apr 15, 2011 08:18 PM
PinklySmooth
Mar 18, 2011 02:00 AM
wiz kidd
Jul 16, 2007 10:54 AM
Ca$$e
Jan 4, 2006 06:43 PM
