6th Gen ('00-'05): MAP sensor
Old Sep 16, 2015 | 04:01 PM
melflorida's Avatar
Default MAP sensor
I'm trying to walk my uncle through a MAP sensor replacement on his 03 3.4, forget it... Does anyone have an idea what a garage would charge for the job??
Old Sep 16, 2015 | 06:20 PM
jim1405's Avatar
Try Auto Repair and Maintenance Estimates | Auto Shop and Mechanic Ratings to get a ballpark cost. In the mpls/st. paul area the actual cost is usually the higher end of the range. I replaced one on a friends grand am gt and the part was about $45 from O'reilly. Only a couple of screws to remove to replace it so I wouldn't think labor would be much but a shop will probably charge you a lot more for the part.
Old Sep 16, 2015 | 11:37 PM
melflorida's Avatar
JIm, thank you so much for your response. Maybe it's me, maybe I'm not giving him a good idea where to find Map sensor. Can you explain to me exactly where it is located? Thank you so much for your time....
Old Sep 17, 2015 | 12:39 PM
jim1405's Avatar
The map sensor is the black rectangular part the plug wires are going over. It's connector is underneath and you can see the ends of the two screws holding it. Piece of cake to get to.
File Type: jpg
Old Sep 17, 2015 | 12:46 PM
melflorida's Avatar
thank you Jim, I was telling him to follow lines etc. your response will get him through it. Appreciate the help....
Old Sep 17, 2015 | 12:58 PM
jim1405's Avatar
Guess there's a youtube for almost everything! Have your uncle check out this. It's for an impala but exactly the same.
Old Sep 17, 2015 | 01:52 PM
melflorida's Avatar
he'll love it..... this is exactly what I was looking for, thanks again!!!!!
