MAP sensor
I'm trying to walk my uncle through a MAP sensor replacement on his 03 3.4, forget it... Does anyone have an idea what a garage would charge for the job??
Try Auto Repair and Maintenance Estimates | Auto Shop and Mechanic Ratings to get a ballpark cost. In the mpls/st. paul area the actual cost is usually the higher end of the range. I replaced one on a friends grand am gt and the part was about $45 from O'reilly. Only a couple of screws to remove to replace it so I wouldn't think labor would be much but a shop will probably charge you a lot more for the part.
JIm, thank you so much for your response. Maybe it's me, maybe I'm not giving him a good idea where to find Map sensor. Can you explain to me exactly where it is located? Thank you so much for your time....
1 Attachment(s)
Originally Posted by melflorida
(Post 672730)
thank you Jim, I was telling him to follow lines etc. your response will get him through it. Appreciate the help....
Guess there's a youtube for almost everything! Have your uncle check out this. It's for an impala but exactly the same.
he'll love it..... this is exactly what I was looking for, thanks again!!!!!
