Major Short To Ground
Old Apr 30, 2020 | 08:48 PM
WolvenScout's Avatar
Default Major Short To Ground
First I had the ICM go out, and that grounded my monte for like two weeks. Now I have a major short to ground, causing it to be undrivable again. What's happening is all the electronics shut off. Everything. Not even a check engine light when turning the key to ON. This has happened twice now, and both times it has fixed itself on its own overnight. But I want to eliminate this issue. I already checked most of the electrical stuff I've done to the car. Mainly unplugging some added lights, checking for wires the windows might've cut into, and taping up all the unplugged connectors in both doors that are no longer used (speakers/switches). I haven't unplugged my dash cam yet, but I might have a theory on what it could be. I completely disconnected the battery while I was addressing all the electronics I've messed with. When I was done, I reconnected it and turned the key to ON. All the usual lights came on. I thought I had fixed it until I tried turning the engine over. As soon as I tried to engage the starter, all the lights immediately went out again. Making me believe the short could be the starter itself, or something in the starter wiring. I did a quick check of the wiring at the starter, and didn't see anything obvious.
Is there something I should check that is known to cause an issue like this?
Old May 1, 2020 | 08:31 AM
I wouldn't think it could be any lights, windows, etc because all that stuff should be fused. If something inside the device or in the wiring was majorly shorted to ground, it would blow the fuse immediately and wouldnt come back on.
Old May 1, 2020 | 02:21 PM
Could it possibly be a bad starter, or starter relay?
Edit: Scratch that. I believe I found the issue. A while ago I installed the ZZP alternator rewire, which routes a thick guage wire from the alternator post directly to the underhood fuse/relay panel. The connector on the fuse/relay panel side was very corroded. I disconnected all the wires from both fuse/relay panel posts and wire brushed it all. I moved the ZZP wire from the bottom post which I had it installed to prior, and installed it to the top post this time. Would the connectors proximity to the battery cause corrosion? It is what looks like a copper connector, or at least copper coated. There is also zero corrosion on the alternator side. Everything seem to work fine now. I'm hoping that is the only issue.
owens91
24
May 2, 2014 01:51 PM
Bob Hulse
Dec 14, 2013 07:47 AM
LostSummer
Nov 29, 2012 05:50 PM
SpaceAce
Dec 22, 2009 12:19 PM
Mike95MonteLS
Sep 25, 2006 01:36 PM
