Lower Control Arm Bushing
i got my driver side hub changed last week, then i my self changed my brakes and rotors. Now my mechanic is telling me that my lower control arm bushing needs to be replaced....is this hard to do? and is there a write up some where on how to do it?...if not can you tell me how? the want to charge me over 170. so if i can do it myself id be much happier.
I had this same issue come up with the shop i brough my car to get service on. They said the bushing needed to be replaced on my left front side and it'd cost between $150-$180. Where is this bushing located and how would I get to? Is it a tough fix or a quick fix? What parts am I looking/asking for at Autozone? Cost? Thanks in advance. I'm far from a car expert and any advice would be much appreciated.
good luck trying to tap the bushing out it's not as easy as it sound. gonna need special tool to press those bushing out. the easiest way to do is buy the complete lower control arm from wbody store dot com or go to orielly. moog make the lower control arm cost $300 for both sides with already new bushing and ball joint. also they have greaseable fitting on them the stock one don't.
http://www.wbodystore.com/grandprix/...air-p-218.html
Opposite Bushing Installation
01 monte carlo ss 3.8 147000
Replaced passenger side lower control arm bushing....went to replace the driver side....but the bushing that needed to be replaced was upside down or opposite the way the passenger side was installed...Is this right...or should I replace the driver side just like passenger
Chriswmasters
03-20-2013 11:13 AM
6th Gen ('00-'05): Replacing a Lower Control Arm
undeadmetalshred
02-02-2012 12:52 AM
