6th Gen ('00-'05): Low Tire Pressure Message does not go away
Old Jul 27, 2014 | 09:14 PM
MonteCarloSS02's Avatar
Default Low Tire Pressure Message does not go away
In the "message center" on the dash of the car, it constantly says 'Low Tire Pressure' even after i have "fixed" the problem. Any help? My car is a silver 2002 Monte Carlo SS.
Thanks.
Old Jul 27, 2014 | 09:27 PM
Aaron0313's Avatar
with the vehicle running pull the headlight **** out one position/click, push it in, pull it out, push it in, pull it out and push it back in all within 5 seconds. It should reset that.
Old Jul 28, 2014 | 12:30 AM
If you still have your factory radio that is what you will use to re-set your message center notices. Look in your owners manual or go on line and read about how to re-set your low tire pressure message.
And Welcome to the Forum!! See this is your first post, nice to see another 2002 Monte show up...
Old Jul 28, 2014 | 08:22 PM
Thanks for the help guys, got it fixed!
Old Aug 6, 2014 | 04:10 PM
TPStatic's Avatar
Yes. Thanks Large.
It was last bubble after:
New tires
Reformatted CPU
HV intake kit from AS
Down pipe from ZZ
KN Air filter
Throttle body mod
33 mm front sway bar
Slotted and drilled disks
New carpet
Kenwood amp and radio with Focal speakers.
Intake mod
Steering pump
Knock sensors
Transmission rebuild
Piece of mind. Priceless
Old Aug 28, 2014 | 10:23 PM
michelob's Avatar
Had the same issue this technique works like a charm to reset it. Thanks man.
Old Aug 29, 2014 | 08:46 AM
panpan's Avatar
This is a much better way than with the radio !
Where do you find these tricks ? Is there a list somewhere ?
A similar technique for the oil change message would be helpful too.
montejass
FWD Tech Guides '95-'07
42
Sep 22, 2021 10:19 AM
big green dog
Mar 14, 2012 02:56 PM
BlackRainSS
Mar 8, 2012 12:09 PM
drmrgal
Dec 8, 2009 08:31 AM
keghead40
Jul 19, 2005 12:13 AM
