Low Coolant Question
Old Feb 24, 2010 | 04:59 PM
bowtie8_3's Avatar
Originally Posted by 01SSMonte
The 3.8 does not have the lower intake gasket leak like the 3.1 and 3.4. It has troubles with the plastic intake breaking. Just did intake gaskets on my sons 97 3.1 Monte. Man it's FUN FUN FUN...........
The 3800 has plastic lower intake manifold gaskets that do FAIL. I just replaced mine after 85k miles and they were melted and deformed. I also replaced my upper intake at the time just to be safe.
Old Sep 21, 2010 | 08:26 AM
cierrajoy18's Avatar
Originally Posted by 05SSMonteCarloSC
I also have a leak somewhere. It is actually wet on the passenger side frame area, directly below the main pully. Not sure if this is water pump, or intake manifold leak.
Other problem is when I am driving, I can smell coolant and my windows fog up. I know on old cars, the heater core was inside on the firewall. I dont know why my windows would fog up just because my car leaks coolant under the motor. Any ideas?
2005 SS Monte Supercharged, 25,000 miles
Hello, It is most likely your heater core, I believe that it is right under the dash on the driver side. My 2001 Monte had the same problem!
Old Oct 11, 2010 | 10:12 PM
04MonteLS's Avatar
So when it's a lower intake manifold gasket, where does the leak come from?
TMoney
Aug 18, 2013 02:37 PM
Monteimpala
Mar 8, 2012 02:32 PM
StanzManianDevil
Feb 22, 2009 11:28 PM
StanzManianDevil
Dec 24, 2008 06:46 PM
RudeRooster
Sep 30, 2004 11:49 PM
