low coolant light
wuz up guys. For a while my low coolant light would stay on no matter how much coolant was in the system. So someone told me to replace the coolant leveling sensor and i did. the light went off. But after i replace the sensor the light still comes on expect now it comes on and off while driving. Any suggesting
Sounds like a bad connection in the wire somewhere, probably at the end at the sending unit, but it could be at any of the connections befor it gets to your BCM, or is it the PCM?
i replaced it like 3 months ago. And no when i removed the radaitor cap it didnt look bad. But guys it starting doing it right after i replace it i also think that it MAY be a bad connetion
hotrodharley
Nov 15, 2013 11:37 AM
TMoney
Aug 18, 2013 02:37 PM
