Low Coolant Light
When it's colder out does the light turn on? and Then the light goes out when the car reaches normal operating temperature??
If you are fine on coolant, I would get that coolant flushed. Dex-cool should be flushed every year (forget the 5 years 100,000 mile mark it says). That should fix the problem. If it does not fix the problem then you would want to check out the sensor, sometimes they get gunked up from the old coolant.
It's probably a bad sensor. I had the same issue in a 96 Lumina. I pulled the sensor, cleaned and reinstalled it first - I was told that they can get gunked up. That didn't help me though. Bought a new sensor ($48 - not cheap) and that fixed the problem.
hotrodharley
11-15-2013 11:37 AM
TMoney
08-18-2013 02:37 PM
