Low beams/Driving lights
Driving lights/low beams are out. Is there underhood fuses I should check and which ones? I really need to get an owners manual/haynes manual. Last night I drove home with my brights held on.. bummer. This happened after I went through a puddle of water, both lights went out. The actual thing on my dash is still reading the light coming in because my dash lights are still responsive at night.
Any help is greatly appreciated.
Maybe I should check my grounds. I don't know where they are, but should they be grounded out somewhere or should I make sure they aren't? Electrical work is not my strength.
So far,
DRL Relay Fine
Parking Lamp Relay Fine
Headlamps Fine
DRL Sensor on dash is fine, still requests lighting for instrument cluster.
Problem:
All driving lights out as in the system will not automatically engage or disengage them in any way.
The brights can be manually used (but won't click in).
Lamp control inside is unresponsive when attempting turn on exterior lighting (not including rear lights).
Sorry for all the posts
Any suggestions are appreciated :x
So far,
DRL Relay Fine
Headlamps Fine
Problem:
Yeah, they run at a fraction of the power in DRL mode from what I understand. I can use the brights at night, by holding back my switch. What throws me for a loop though, is that they won't be activated as DRLs during the daytime, but I still have power to them (to use them during the night).
My night-time lights aren't turned on through the auto headlamp system either (besides the sidemarkers), and I think it would follow that the reason I wouldn't be able to click in my brights might be related.
