Loud POP
Well I was driving back to work from my lunch break and I heard a loud pop on the front end. Almost as if you would run over something or hit a pot hole. I parked at my job looked under the car and im leaking fluid. The tow truck drive said it was clear fluid. Anyone know what this could possibly be?
The only issue I have been having is this annoying fast clicking sound when I unlock the car and it also happens like every hour or so and I think Im starting to have cv axle failure but not 100% sure on that one. But like I said it was still driving like normal. Brakes were working fine. Power steering was fine. Im just waiting on that call from the mechanic.
OK, the fluid was condensation from the drain, normal when using AC. Didn't think of that one...
Glad your mechanic found the issue and you'll be back on the road soon!
Hi, I think my cc axle is bad also. Where are you located and what kind of price did you get for a replacement.
A Monro auto center outside of Pittsburgh, PA quoted me $200-$300 for this.
I'd like to compare pricing because an online estimator said $300-$700, which seems to be a really wide range.
Thanks,
Donna
Thanks,
Donna
labnjab
07-24-2009 07:51 PM
