LOST SOUND WITH AFTERMARKET RADIO Please help!!
Newbie here ok, so here's my problem I tried installing my new double din pioneer avh-x4500bt head unit wired everything according to the diagram plugged it all in then turn it on and no sound I can hear something but that's only if it's extremely quiet and I make no sudden moves inside the car I checked all speakers to make sure they're not grounded out everything seems fine I have no stock amp I'm just completely lost I wanna know if anyone has the same problem and have the found the issue, head unit is not bad I've already tested it also I'm using American international wiring harness gwh-406 2006 Chevy Monte Carlo LT no onstar no Bose just incase your wondering please someone help me!!!
Sorry, I didn't see where you specified you didn't have a factory amp. The Bose system was an option. You could still have a factory amp and not the Bose upgrade. Take a look (from the trunk) up under the rear shelf. If there is a rectangular metal box hanging there with a couple of wiring harnesses plugged into it that is your factory amp. To bypass it you'll need something like this:
Metra 70-2021 Factory Integration Adapter Connect a new car stereo and bypass the factory amp in select 2000-01 Chevy Monte Carlo and Impala models at Crutchfield.com
hey
X2 on the factory amp thing kind of a thing with modern cars
