Opinion Needed: lil rough on start
Old Mar 18, 2015 | 04:58 PM
02ssintimidator's Avatar
Default lil rough on start
My 02 ss runs a lil bit rough on start up. After a few secs it runs fine. What should I do before it gets worse?
Old Mar 18, 2015 | 08:25 PM
ohara's Avatar
How long has it been since it had a tune up? may need a new set of plugs and wires
I would also run the tank low and when you fill it up put a can of seafoam in the tank and run it through, it could be a carbon build up, or bad gas. This is a cheap fix that may work and the one I would try first, as plugs and wires cost money lol,
Old Mar 18, 2015 | 09:18 PM
JC Colon's Avatar
I agree with Ken. A good tune up. Sea foam in a Fresh tank of gas. Check all your wires for cracks and dry rot. Also have your PCM scanned for stored codes.
Old Mar 18, 2015 | 11:03 PM
Default Thanks
Thanks for the advice I appreciate it. Just bought the car so not exactly sure when the last tune up was. The seafoam works good? I never used it before. I'll try that and check my plugs and wires just to be sure.
Tadcaster
Aug 24, 2012 06:01 AM
blackbeauty89
Mar 13, 2012 11:53 AM
blondeguy64
Mar 10, 2010 07:44 PM
les1178
Nov 29, 2007 07:46 AM
