Leaking Steering Fluid Line - Pics
Old Mar 21, 2014 | 07:25 PM
lala3488's Avatar
Default Leaking Steering Fluid Line - Pics
Hello All,
I have been having an issue with my 2004 Monte Carlo. The steering fluid line has been leaking. We removed the passenger side tire and discovered that a plastic covering rubbed on the line causing corrosion. All of the fluid is leaking out at one time. My question is; Will I be able to replace the section of the line that is leaking, Or will I need to replace the entire line. Would we be able to use a high pressure rubber hose for this section? I will post links to photos
http://i306.photobucket.com/albums/n...r/IMG_0952.jpg
I am unsure if IMG links will work;
oaky812
Aug 7, 2024 03:49 PM
deezdrama
Jun 7, 2012 08:01 AM
24_48Fan
Apr 9, 2011 08:01 PM
bikerboyzzky
Mar 20, 2011 09:24 AM
SamanthaF
Nov 16, 2010 09:41 PM
