Knocking noise
Old Oct 28, 2013 | 07:57 PM
cali2000ss's Avatar
Default Knocking noise
I have a 2000 Monte Carlo SS 3.8 and lately I have a knocking noise from top of the engine and there are days that the noise is gone. It sounds like a loose valve but I have no power loss and the car runs good except for the knocking noise, Does anybody know what could cause this ?
Old Oct 28, 2013 | 08:24 PM
It's hard to say, if the noise sounds internal, 90% of the time it's cause of a bigger problem.
Does the noise go away as the car warms up?
Old Oct 28, 2013 | 08:40 PM
cali2000ss's Avatar
sometimes it does other times it keeps knocking
Old Oct 28, 2013 | 10:45 PM
72chevman's Avatar
check motor mounts. I've had two crack and had some bolts loosen up on another after dealer did some work and did not tighten them all the way I assume.
Old Oct 28, 2013 | 10:55 PM
Mac7504's Avatar
Tick or definite knock?
No check engine?
Old Oct 28, 2013 | 11:57 PM
No check engine?
Good point, as would not a knocking sound activate the knock sensor causing a Check Engine Light with a P0327 or associated code . Where as a tick would not and it could just be a lifter problem..
Old Oct 29, 2013 | 01:05 AM
cali2000ss's Avatar
its a ticking noise
Old Oct 29, 2013 | 01:06 AM
cali2000ss's Avatar
no check engine light is on
Old Oct 29, 2013 | 01:34 AM
Originally Posted by cali2000ss
its a ticking noise
A ticking noise could be an intermittently stuck lifter. This could be a simple easy fix fior you. Here is one link repairing sticky lifters, there are others just search about, they are all basically the same. Good luck, maybe others will chime in for you to.
Click on link below:
How to Get Rid of a Lifter Tick | eHow
MdotCdot
Apr 26, 2014 01:18 PM
03SSChevyFun
Aug 16, 2013 06:27 PM
InfamousFlip
Mar 14, 2013 04:11 PM
augi
Oct 13, 2012 10:25 AM
clayg80
May 4, 2005 11:10 AM
