Knocking noise
I have a 2000 Monte Carlo SS 3.8 and lately I have a knocking noise from top of the engine and there are days that the noise is gone. It sounds like a loose valve but I have no power loss and the car runs good except for the knocking noise, Does anybody know what could cause this ?
It's hard to say, if the noise sounds internal, 90% of the time it's cause of a bigger problem.
Does the noise go away as the car warms up?
Good point, as would not a knocking sound activate the knock sensor causing a Check Engine Light with a P0327 or associated code . Where as a tick would not and it could just be a lifter problem..
A ticking noise could be an intermittently stuck lifter. This could be a simple easy fix fior you. Here is one link repairing sticky lifters, there are others just search about, they are all basically the same. Good luck, maybe others will chime in for you to.
Click on link below:
How to Get Rid of a Lifter Tick | eHow
6th Gen ('00-'05): Mysterious knocking noise
03SSChevyFun
Aug 16, 2013 06:27 PM
InfamousFlip
Mar 14, 2013 04:11 PM
