Knock/Thud in front end of '05 LT
Old Oct 26, 2009 | 08:27 PM
saigashooter's Avatar
Well, looking at the cost of any potential repair, I wish it was just the tires but they are only about 11 months old, and in great shape. Guess I'll take it in in the next week or so for the oil change and have they mechanic give her a once over. I hate car repairs.
Old Mar 23, 2010 | 08:06 AM
cornerview's Avatar
*bump ............ saigashooter , what turned out to be the issue ????
Old Mar 23, 2010 | 10:19 AM
Not yet, but I think it may be the intermediate steering shaft, all the symptoms fit to a T. there is a lube kit that GM has to "solve" the issue. I will give that a try when I can get my hands on it. Why doesn't someone just make a better shaft? they use it in the Monte, the Impala, the Grand Am and Grand Prix, and I think the Malibu too.
Old Mar 23, 2010 | 10:26 AM
Don't buy any kits. Do you have a spray white lithium grease? Just use that. I can give you instructions if you want.
Also, check all of your bushings, maybe one of them have gone bad?
Old Mar 23, 2010 | 12:29 PM
cornerview's Avatar
so have you been driving your care since you made the original post ? im not fussing, im curious because i JUST noticed this happening with mine and i absolutely need my vehicle for the next 5 days until i can get it to my uncle / mechanic. i just hope im not making the situation any worse by continuing to drive it
Old Mar 23, 2010 | 01:33 PM
Yes I have been driving it, it's the only car I have. I cringe a little every time I hear it.
Mike, can you post up a guide for the spray grease?
Old Mar 23, 2010 | 01:39 PM
Basically you want to just use a white lithium spray grease (Like This)
Go under your steering wheel and above the gas / brake pedals there should be a plastic cover that is just held on by 2 clips, depress those and remove the cover. Now you will see the ISS, but it has a plastic boot covering the part you need to spray, just pull back on the plastic boot and you will see a green/teal thing, and the knuckle for the ISS. This is what you need to spray. Turn your steering wheel one way, spray, turn the other way, spray.
Close up and enjoy.
Old Mar 23, 2010 | 02:13 PM
That looks much simpler than the GM way. Will have to do that this weekend along with the brake job.
Old Mar 23, 2010 | 02:20 PM
It is very simple, I do it once a year.
Since GM has yet to fix the problem, there's no point replacing the ISS, or even taking it out for a full greasing.
ymhajoe
May 16, 2014 10:29 AM
milrlyt
Jan 11, 2013 11:38 PM
kschmidt319
Oct 29, 2010 11:50 AM
yzf125
Apr 30, 2006 11:21 AM
warpath
Apr 6, 2005 09:20 PM
