jerking and stuttering
Old 12-31-2009 | 09:51 AM
robc's Avatar
where or who would test a cat,i never had to so this before?
Old 12-31-2009 | 11:51 AM
East's Avatar
I'm not exactly sure how to go about it, but I am sure a reading of pressure is needed pre-catalytic converter. If you dig around via the search box here, you can find the exact psi which indicates a healthy catalytic converter. You can probably locate this on google as well. I found it last night, but didn't bookmark. Just a word of caution though, the back pressure caused by a failing catalytic converter can place a disastrous amount of strain on your engine, so if you do confirm it to be the problem be sure to replace it as soon as possible.
Old 12-31-2009 | 12:01 PM
oops, nevermind you have the 3.4
Was going to post link to ZZP Downpipe.
Old 12-31-2009 | 12:15 PM
RocknSS04's Avatar
Isn't there a 3.4 downpipe available somewhere?
Old 12-31-2009 | 12:17 PM
East's Avatar
Hey you should anyways, I'm definitely interested in exploring that route. If you also have any youtube videos that could give me an idea of how it sounds and any extra info that would be cool. I'd have to equal out that mod with better air intake, right? I really don't feel like replacing my catalytic converter again if it ends up being my issue this time around, because from what I understand failure is likely to persist in 00-04 models, right?
Old 12-31-2009 | 12:23 PM
I think ZZP Discontinued the 3.4 Downpipe.
Here's the 3.8:
https://www.zzperformance.com/grand_...=551&catid=110
all options are explained on the page, do some long indepth reading.
Old 12-31-2009 | 12:35 PM
East's Avatar
Thanks.
Old 12-31-2009 | 04:28 PM
gmcman101's Avatar
My 03 was doing the same thing. Mine is a 3.8 and it turned out to be the FPR.
Old 01-01-2010 | 06:51 AM
robc's Avatar
Default fpr?
fuel pressure regulator
Old 01-01-2010 | 07:06 PM
robc's Avatar
your fuel pressure regulator was causing that,only at those speeds and rpms?
