7th Gen ('06-'07): Intimidator Badges
There are two versions (and I am not affiliated with any seller) a vinyl decal type badge and a chrome raised letter type badge.
I went for vinyl for a cleaner, flatter look, while the raised letter one looks more stock; and true to the Intimidator Monte Carlo and Silverado factory badging.
- Either way you go, get some paint prep or alcohol pads and clean the area where it is going.
- Take your time measuring / eyeballing / painters-taping and line it all up right; you only get one shot.
- Be very careful pealing the adhesive backing paper from the application front, and peel very slowly. (The dotted 'i's didn't want to cooperate at first.)
- When applying the decal, press slowly, front to back, and even trace the entire thing by pressing the letters with your finger for adhesion when it's on.
- When it's stuck to the car, peel the application tape slowly away from the badge at almost a 180* angle, so the tape doesn't want to take the badge with it.
Plus, take pictures when it's all done. I'll share mine here when I get a chance. Best of luck; you'll be happy with the outcome!
