install electric fan
Old Dec 28, 2012 | 03:17 PM
etvalentin's Avatar
Default install electric fan
Has anyone installed an electric fan?...If so, i'm looking to install one on my 84 with a 305...I need to know some spec information on what fan to get...they ask push/pull, height, width, # of blades...I have no clue...any help is appreciated....
Old Jan 3, 2013 | 11:56 AM
DixieMonteCarloDepot's Avatar
Have you every looked into the lincoln mark VIII fan? They fit perfect on a G-body radiator.
Old Jan 3, 2013 | 01:06 PM
etvalentin's Avatar
I haven't, but I will now...besides the fan, what else will I need...an electrical kit I would suspect?....
Old Jan 3, 2013 | 03:01 PM
It depends on your wiring skills and how detailed you want to go, toggle switches is one option or you can put a thermostatic relay in and have it kick on and off with the temperature.
Rob@dixiemontecarlodepot
Old Jan 13, 2013 | 10:11 AM
jakefluker's Avatar
Very good old school advice,alot of people dont know how reliable and affordable those electric fans are, only trouble is finding one...check local junkyards or ebay.i had a book or catalog (something) that explained how to install and parts needed etc.will try to locate info and post it
Old Jun 7, 2013 | 08:11 PM
John1P@aol.com's Avatar
i just installed one in my monte! best upgrade so far. heres the thread-
Electric fan upgrade!! Imma need help.. - MonteCarloSS.com Message Board
Old Aug 17, 2013 | 12:44 PM
wvmontels's Avatar
If you mount the fan on the side of the radiator towards the engine, you want it to push. I learned that the hard way lol.
Old Aug 18, 2013 | 08:52 PM
If the fan is mounted between the engine and the radiator, you use a puller so it can work with, not against, the air coming through the grill...
Old Aug 19, 2013 | 05:42 PM
wvmontels's Avatar
Oh gosh, my bad, I said it wrong, you're right it has to pull if it's between the engine and radiator. I thought it'd be better to use a bigger fan on my 87 Monte. Unfortunately this bigger fan came off a serpentine setup and went to a reverse-rotation water pump. Needless to say it got really hot after about 20 minutes or so of driving. I put the old stock fan back on it and fixed it. That's how I learned about the importance of push/pull when it comes to your cooling fan.
Old Sep 26, 2013 | 02:32 PM
etvalentin's Avatar
So I installed an electric fan...it's a 2050 CFM...I have a 185 degree thermostat, and the switch for the fan is also a 185...I also added a toggle switch to turn it on when I want...the problem is, I went for the first ride yesterday and sat in some traffic...it wasn't that hot, around 70 or so, and I wasn't in traffic for long, maybe 15 minutes of stop and go...the temp got to 210 and 220...I pulled over and sat for a while, then went right home...when driving it's fine, but sitting, it's getting really hot...the waterpump is brand new...radiator isn't...I think it's the stock radiator...
My question is, is the fan not powerful enough, or do I need a newer radiator with 2 core?....
P343
Mar 22, 2015 11:23 PM
testcase448
Aug 16, 2014 02:20 PM
Gthirteen
Apr 3, 2011 06:25 AM
gentlejax2
May 28, 2008 04:29 PM
