5th Gen ('95-'99): Ignition Sometimes Won't Release Key
Old Apr 29, 2013 | 06:29 PM
Luminator's Avatar
Default Ignition Sometimes Won't Release Key
I have a 1998 with an intermittent problem. About half of the time when I park the car and turn the engine off, the ignition key won't come out right away.
Sometimes all I have to do is wait a minute or so, and listen for a sort of "kachoong" sound coming from the floor shifter area, then at that point I know I can turn the cylinder all the way back and remove the key. Other times I just have to take my chances and leave the key in until the next time I drive.
Is something just slightly out of adjustment, perhaps? Like the transmission isn't fully engaging in Park somehow? Or is the problem more electrical in nature?
Old Apr 29, 2013 | 08:59 PM
zzapultimate's Avatar
The Kachoong you describe sounds like the shifter isn't sitting in its detents correctly. Try popping off the bezel around the shifter and see if you can see what is going on in there.
Old Apr 29, 2013 | 11:15 PM
03Monte's Avatar
i have this issue after my ignition cylinder had to be replaced... i have to push the shifter a bit more forward and the key will release...
let me know if this helps!
hacknfrack
Aug 3, 2013 10:50 PM
96chevyridinheavy
Mar 23, 2013 10:21 PM
96chevyridinheavy
Mar 17, 2011 07:53 PM
jeff2425
Dec 10, 2009 10:50 AM
jeff2425
Dec 9, 2009 07:05 AM
