Ignition Lock Cylinder Access
Old Oct 1, 2018 | 01:46 PM
Emily Seastrand Hall's Avatar
Default Ignition Lock Cylinder Access
How are you supposed to get to the ignition lock cylinder? I took off the dashboard, but there's a metal plate welded in place under the steering column. Is there another way to access the cylinder? My PCM won't let my car start. Yes, I've tried the Passlock Reset. The security light never goes off and the car refuses to crank. The starter is connected properly, but doesn't get what it needs from the ignition cylinder. I tried sending power directly to the starter from the battery and just ended up frying my fusable link. I'm supposed to be moving in two weeks. Help.
Old Oct 1, 2018 | 04:40 PM
Smile try this
try this
Old Oct 3, 2018 | 01:54 PM
The holes he puts the socket wrench through around 4:45 are not present in my car.
Old Oct 3, 2018 | 06:54 PM
Smile
Can you get to them with a ratcheting box wrench? if not maybe drill it out start small when you do that? Or Call them guys at A1 auto and tell them what you got they will help you solve it.
Hunter Kost
May 12, 2017 07:54 PM
ohara
Nov 12, 2015 06:42 PM
JayBay
Jul 8, 2013 07:31 PM
jeremyjlewis02
Oct 24, 2011 01:28 AM
big green dog
Jan 7, 2010 11:18 PM
