Ignition cylinder lock STUCK
Old Feb 2, 2008 | 05:22 PM
greatness107's Avatar
Default Ignition cylinder lock STUCK
OK GUYS I TAKING APART MY DASH NOTHING MAJOR SEEING WHAT HAD TO BE TAKING APART FOR MY AFTERMARKET RADIO INSTALL. I had the key in the ignition on ACC . i didnt disconnect any eletrical componets. One i saw what i need to see for my radio install i put my dash back together and i removed the key. WHEN I PUT THE KEY BACK IN AND TRY TO START MY CAR THE IGNITION WONT TURN...... WHERE DID I GO WRONG???? AND WHAT WILL FIX IT
Old Feb 2, 2008 | 06:00 PM
Default RE: Ignition cylinder lock STUCK
[align=center]Hi Hollywood,[/align][align=center]Please post what year/model Monte Carlo ?[/align][align=center]Do it has the Pass Key System ?[/align][align=center]Don't feel like you are alone, I've torn things apart, and[/align][align=center]couldn't put them back together, & `if I could they never[/align][align=center]worked again. : )[/align][align=center]It's difficult to give you an answer, or a solution since we [/align][align=center]are not there to check your work.[/align][align=center]I will look for your reply on the above needed facts.[/align][align=center]`Space[/align][align=center][/align][align=center]In my Monte CarloPost "How do you drive you Monte,[/align][align=center]I have a link there that tells you how to how wire your car : )[/align][align=center]It may be something else to look at until you can find the[/align][align=center]problem...Good Luck[/align][align=center][:-]Click 2 be able 2 steal your car : )[/align][align=center][:-][/align][align=center]How to Hotwire a Car[/align]
Old Feb 2, 2008 | 06:24 PM
2000LS's Avatar
battery isnt dead is it?
Old Feb 2, 2008 | 07:06 PM
its a 2001 monte carlo SS and basically after i put the dash back together the
Key won't turn in the ignition to start the car. But u can pull the key out fine[/align]
Old Feb 2, 2008 | 07:14 PM
2000LS's Avatar
bezel around the ignition possibly not fully seated, keeping the key from being fully inserted? might try just poping it off to be sure.
dbaldwin
Jul 2, 2014 12:32 AM
jim1405
Sep 24, 2012 04:40 PM
Holly19
Nov 18, 2011 06:14 PM
jeremyjlewis02
Oct 24, 2011 01:28 AM
slinkeey
Dec 8, 2009 07:54 PM
