7th Gen ('06-'07): Idle Fine and Smooth, Rough Crusing
Old May 9, 2025 | 09:08 AM
MikeMcD1973's Avatar
Default Idle Fine and Smooth, Rough Crusing
I have a 2007 Monte Carlo SS and I just replaced the Bank 1 Knock Sensor but I still have a problem. While in Park or Neutral, runs nice and smooth, but as soon as I start moving all the sudden it starts running rough unless I give it some gas and it runs normal for a moment, I have to put it in neutral to take a corner because it acts like it wants to cut off, as soon as I put it in neutral, problem goes away. Anyone that can give advice on what my problem may be I would greatly appreciate it. This is my 2nd Monte Carlo, I had a 2004 with a V6 for (18) years but it caught on fire in my driveway, this is the only kind of car I have driven since 2004 so please help if you can. Thanks 🙏
Old May 9, 2025 | 09:32 AM
The easy place to start - is it throwing any codes, either active or pending?
What prompted replacement of the knock sensor?
What's the age /mileage of the ignition system components ( plugs, wires, coils)? Also would be helpful to know mileage of the car in general.
How does fueling look at idle and when its having issues - is the O2 pegging rich or lean, or are there any strong trends in fuel trims (short and long)? Do you have a way to check fuel pressure?
Did this start all of a sudden one day (went from 100% good to 100% bad in an instant) or was it a minor problem that kept getting worse and worse over time?
TrillWill
Jul 20, 2016 06:21 PM
b1chmonkey
Feb 16, 2014 10:25 PM
YelloJac
Feb 24, 2013 11:48 AM
itsjustme
Oct 20, 2010 02:37 PM
Brinksta
Jul 16, 2008 06:49 PM
