7th Gen ('06-'07): Hyper flash fix 07 SS
The 06-07 Monte uses a different Flasher Module than the 00-05. I never looked into the 06-07, but I believe the chip found in the 00-05 flasher modules is pretty common with other modern flasher modules. If it is of any help, below is the link to the process to mod the 00-05 Flasher. Welcome to see if that helps:
https://montecarloforum.com/forum/fw...signals-61550/
I looked in Impala forums and the sad news is that the flasher is controlled by the BCM. Might be better searching there since I think the Impala is the most common W body of that vintage.
7th Gen ('06-'07): Things to consider when buying '07 SS
DFresh
May 21, 2021 09:19 AM
