7th Gen ('06-'07): Hyper flash fix 07 SS
Old Feb 4, 2024 | 07:42 PM
KcChiefs2323's Avatar
Default Hyper flash fix 07 SS
Anyone know how to fix hyper flash on 07 ss? Tried resistors with no luck. Any ideas would be greatly appreciated
Old Feb 5, 2024 | 09:19 PM
Barovelli's Avatar
Find @The_Maniac here and see if his modded flasher will work.
Old Feb 6, 2024 | 10:22 AM
The 06-07 Monte uses a different Flasher Module than the 00-05. I never looked into the 06-07, but I believe the chip found in the 00-05 flasher modules is pretty common with other modern flasher modules. If it is of any help, below is the link to the process to mod the 00-05 Flasher. Welcome to see if that helps:
https://montecarloforum.com/forum/fw...signals-61550/
Old Feb 7, 2024 | 08:23 PM
Barovelli's Avatar
I looked in Impala forums and the sad news is that the flasher is controlled by the BCM. Might be better searching there since I think the Impala is the most common W body of that vintage.
77gp
24
Feb 26, 2022 10:29 AM
SSdougiedoug
Feb 20, 2022 08:26 AM
DFresh
May 21, 2021 09:19 AM
John1980
Jul 11, 2017 07:36 PM
FinalSS
Jul 28, 2011 08:30 AM
