3rd Gen ('78-'80): Hub assembly hot
Old Sep 26, 2020 | 04:48 PM
Cyle Kasper's Avatar
Default Hub assembly hot
Recently purchased a '78 Monte to restore. After replacing the rotor / hub assembly in the front, I noticed the hub was pretty warm after a quick test drive. Not too hot to touch, but pretty warm. Is this normal? I replaced bearings (packed them), castle nut, and seals when installing both sides. Both front hubs were warm.
Is it ok for the hub to get warm or should I be worried?
Old Sep 27, 2020 | 10:12 PM
Jeffs02rwdSS's Avatar
There's going to be some heat yes, between the brakes heating up the rotors and just the bearings causing heat. Other things to consider is the preload on the bearings. Too tight or loose will also cause excessive heat. Good luck
Old Oct 14, 2020 | 08:30 PM
thanks for the response. I got the brakes done finally after replacing the master and booster and a ton of bleeding.
silveradoman298
Aug 12, 2013 12:02 PM
mike.bayville
Jul 11, 2013 10:16 PM
VictoryRedSled
Jan 28, 2013 04:18 PM
john213la
16
Mar 15, 2012 08:41 AM
Xraycatj
Mar 26, 2011 07:43 AM
